Globally filter displayed data (Media providers, libraries, only offline media, ...)
Symfonium offer a consolidated view of all your media providers and their libraries.
There might be times where you want to filter the visible data to only show specific libraries or media that are only available offline for example.
If you enable the Available offline filter, then only media that are cached locally will be played.
Note: A lot of screens also have contextual filters that only apply to them. See Sort, filter and configure display modes in library views
You can do that easily in most screen by just pressing the global filter button on the top right of the screen.
When in the filter view, you can click the media providers cards to completely hide a provider or you can click on specific libraries to only hide specific ones.
Playable media only (Version 9.0+)
When enabled this filter automatically hides all media that can’t be played (Provider offline and media not cached for offline use)
Media available offline
When enabled only media cached on the device can be played to ensure no media playback streamed from your server.
Hide unavailable providers
When enabled offline providers are automatically hidden
How does sync "Work"
Switching Media servers
Intelligent filters
Search Interface - Show Bitrate (of each result)
Automatically update filter to "Available Offline"
Navidrome content not showing
Toggles to enable/disable a media provider
My homescreen is completely empty
Settings - Manage media providers
Same library for internal and external IP
Custom Headers only sending on initial sync
Toggleable Offline mode
Getting the program to find my music on the SD Card
Frequent apparent loss and recover of data
Synced Library not appearing in Symfonium
Help please! Only showing downloaded tracks
Filter option to show media _not_ available offline in global filter menu
Add ablility to enable/disable media providers
New albums missing until cached offline
Playlists disappeared
Filter By Plex Library
Media Providers not combined?
Can no longer connect to Plex server remotely
Basic quick test of Android Auto and I'm lost
Can't connect to Server outside WiFi
Is there support for multiple libraries?
Cannot play non-offline-cached media over mobile data
Audiobookshelf — Separation of Concerns
Only downloaded media are shown when on VPN
Explicit offline mode for poor connections, display cached media only and retain metadata image cache
Libraries Frequently Show Nothing
Chaning double and triple click skip 30s does not work for me
Cache indicator icon on album view
ID between Local storage vs Server
Second IP address for online media servers
Music is only viewable from the files category, despite working yesterday and resyncing with my server
Unable to open path to a specific library
Looking for a very, very simplistic style
Audiobooks setup?
