Symfonium can backup and restore it’s settings and media providers. (More will be later at a later point)
Backup
When you create a backup you need to select what the backup will include and put a password.
The password is used to encrypt the file, do not forget it!
Important:
- The backup files are internal to the application and needs to be exported in the Manage part to either another location or a cloud provider else they are deleted when you uninstall the application.
- Some data in the backups are tied to the providers, you must export and import both media providers and the data to be able to restore.
Restore.
You can restore previous backups by just clicking on them in the last backups lists. This will require your password.
You can also directly load a backup file from Google drive or other locations by clicking the Pick a backup to restore button.
