Notes:
Interface
Show media item counts
Display a small line at the start of list with the number of items in the list.
Song additional information in list
Songs can display 2 more additional information in list like rating, favorite, offline status.
Song second additional information in list
Smaller images in details views
Use a smaller image in album, artists and genre detail pages
Hide top button row in lists
Media lists have a row of buttons at the top for quick play all, shuffle, mixes. Check this option to remove it.
Show queue next as drop target
You can drag and drop most media in the app for quick playback action. By default only play, queue and shuffle. Check this option to add a queue next option (Might not fit on small screens).
Show playback messages
Show a message when starting most playback action to know the action is being handled by Symfonium. Useful when playing to remote renderers slow to start playback for example.
Action
Default song action
The default action when clicking on a media. (Play, queue, …)
Personal mixes size
The number of items to queue when starting mixes.
Advanced
Clear image cache
Clear the image cache. Useful if you changed a lot of images on your server or switched to another server.
High quality Images
Store the cached images in a lossless format, while this increase the quality a little, the space used is increased by a lot.
Use ascii sort
Android sorts can either be case insensitive (A = a) or respect Unicode switch the option depending on your usage.
Ignore articles for sort names
When a provider does not provide sort names, remove know articles from the titles for the sort names.
Disable library auto sync
Disable automatic sync of the libraries. See Sync media provider data to do it manually
Remove empty albums, artists and genres
If after a sync an album, artist or genre have no associated media then remove it from the library.
Restore defaults
This button restores all settings on this page to their default values. You can also use the backup and restore function to switch between different configurations of the settings with ease. (Settings - Backup & restore)
