Where can I view which media I’ve cached or downloaded? I’m looking for a simple filter or button that says “Downloads” or “Cached.” Currently, if I go offline I can’t browse any of my music. Instead, it says “Nothing to display” and nothing shows up. I would expect the permanently cached media to still be there. It seems like there might be an “Available offline” filter somewhere?
I’m on Android version 14.0.0
I’m new to Symfonium, so hopefully this is an obvious one that I’m just not seeing for whatever reason.
I’m trying to figure this out too. First day using this and I think I’ve explored all options. Do I need to set up the local file search for the Plex download directory? Or must I sync again? (didn’t work)
I’m also interested in this. I went on a road trip recently and downloaded a bunch of music for offline listening, and I’d like to continue listening to that while at my office job that has spotty wifi. I can browse by album (if I’ve remembered which ones I downloaded), but I prefer just shuffling all of my music together.
Try either of these two options:
- From Source Filter menu (funnel icon), toggle the “Hide media not available offline”
- In Library screens (e.g. albums, tracks, etc.), set a Smart Filter rule for “Offline status”:
The rule can be “Saved” with a name so that next time you can just tap a button to toggle the rule on/off.
You can also enable Settings → Interface → Media lists ->(Second) Additional track information in lists → Offline cached to see a small icon behind every track indicating whether it has been offline cached or not.
