Unique symfonium playlists
Currently Symfonium lets me add a single track multiple times to a same local playlist. Ability to have a playlist which will only allow unique tracks (or ignore duplicate tracks if added again) would help manage offline playlists better.
My library is moderately huge and I accidently add the same tracks to playlists. I frequently find myself deleting the duplicates. Having the ability to filter out duplicates in a playlist would be a big help
Better management of offline playlists
Youtube playlists doesn’t allow duplicates in a playlist, if we try to add a track thats already present in a playlist then it would show checkboxes for the playlists if present already
There’s already a discussion about this, some users do want to have duplicates and I did not want to add a setting for this quite specific need.
The current validated solution is that there’s a remove duplicate in the playlist 3 dots menu to clean up the playlists automatically.
This seems to cover most needs.
Thank you, I wasn’t aware of the Remove duplicates option in the playlist menu.
That works for me. Can we show the number of duplicates removed in the toast too.
Yes I can, will be in next relaese.
