Understanding Symfonium Sync with Navidrome
Hi,
I’m mostly trying to understand if I’m doing something wrong, or if I need to change a setting, or (and this is probably the most likely) I’m just stupid.
I love Symfonium and I’m using it all day everyday, the only issue I’ve found in my workflow is that when I add new music to Navidrome, it never shows up in Symfonium until I do a manual sync.
I just want to know, is this expected behaviour?
I’ve read quite a few forum topics, including this, this and (sorry new user can only add 2 links)
Upload description: @tjh issue with auto sync
Latest version of Symfonium from the Play Store
Navidrome running behind Apache Proxy, Apache has SSL cert on it.
Open Symfonium
Play some music
Check the “Latest Albums” filter
Download some music, add it to Navidrome
Confirm it appears in Navidrome’s “Latest Albums”
Check Symfonium see if albums is there, it’s not.
Run a sync.
Confirm album appears (it does)
Subsonic - Navidrome
PS: If I am being very stupid and the answer is clearly on the forums, please just tell me “The answer is here go looking” and accept my apologies in advance.
Symfonium is offline first so yes needs sync.
It tries to auto sync, but have throttling and do not check all the times.
You can use the API to automate sync more often, or pressing the sync button is the normal way.
Thank you - appreciate the prompt response.
