Add a feature that triggers a library full-sync from time to time. This sync could be configurable to happen only once a week AND only when connected to Wi-Fi AND only if the device is attached to a charger (or something like that), you get the idea.
After I learned that it is not possible for some backends (e.g. Jellyfin) to automatically incrementally sync some data like favorites as described here:
It seems like the only way for Jellyfin users is to manually trigger a full-sync from time to time. Problem is that usually at the moment you notice that data is not sync, it is a bad moment to trigger a full-sync because you are maybe just on the road or something. Also it takes time and it is not nice to manually.
It would mitigate the lack of incremental syncs for such backends, and it would remove the need to trigger a manual full-sync for the user (in most cases).
Implement an incremental sync API for affected backends ![]()
