Since some time now I am facing a problem I did not have earlier.
The problem is : when I select an album and ask Symfonium to play it, it really often plays the same track twice before skipping to next one.
Here is some info :
latest Sympfonium used on Android 13 powered by MIUI 14 on mi Pad 5 ;
music stored on Emby server ;
music transferred to be played on Raspberrry Pi4 with rAudio.
If I am the only one, the problem is on my side and probably not Symfonium related (I have a lot of problems anyways).
If I am not the only one, then this is maybe a “bug” andf I’ll provide logs to try to help ironing it out.
Be sure to read the following link for how to gather logs.
Any issue without the logs can be automatically closed without any further notice.
Add as much details as possible, including reproduction steps.
You can try to disable the option upnp gapless in the settings to reduce the issue, but it would be better if what you use returned correct metadata for the items.
What I use is rune Audio on a Raspberry pi4 in it’s latest form (rAudio-1 by a guy called rern).
I will report this to him also see if there a setting I should enable somewhere on that side.
As a side note I am listening to the same album as the one I was listening to for the log file and that Android software has no problem playing all tracks as they should But they not as feature rich as Symfonium and I would like to keep using Symfonium
