How to gather logs and open an issue
Symfonium is a sophisticated application with extensive support for a wide range of providers and players. Troubleshooting can be challenging without the necessary details and logs specific to your unique configuration.
Fortunately Symfonium have a powerful debug mode engine that can be enabled to easily gather those informations.
It gathers the necessary data to be able to see what is happening and is required to be able to fix issues.
Once you have the logs reproducing the error, you can securely upload the file by via : https://upload.symfonium.app/. (Secure file sharing with support)
Only me will have access to those files and they will be auto deleted after usage.
Notes:
  • Do not forget to add your forum name, your issue name or your email in the description field so I can match the files with you.
  • You can use the upload page to join files like media files for tags issues, or videos of the issue, …
You can then head to Symfonium support and follow the wizard.
Generate logs
Note: Logs generation slows down the app a little and can take a lot of space, do not forget to disable debug mode when you have finished reproducing the issue.
To enable logs just go to Settings then Advanced and check the Debug mode option.
You can then reproduce the issue while the logs are activated. When you are done press the Share logs with support button to automatically zip the logs and prepare the mail for support. You can still change the mail destination if you want to check the logs content first. (All passwords/tokens are automatically redacted in the logs).
If you cancel the logs sending you can still access previously generated logs from the Manage Symfonium generated files menu.
You can then delete or share the files. If the app freeze then you can also find ANR reports here that the support will need to investigate.
