If you have any issue with Symfonium please look in the docs because very often the answer will be there. See below for direct links for the most common issues.
If you still have an issue, open a new thread in the support section of this forum and be sure to follow the template and add the mandatory logs. The application is now mature and well tested. Your issue is specific to your setup and requires some information to be properly analysed. Remember that the application supports dozens of media providers and a vast range of Android devices.
If you miss a feature and want to make a feature request, go to the Feature requests section of this forum and open a new one or comment on an existing one. Filling the template ensures that you properly explain your need instead of implying a solution you think would fit. I have a lot of experience in developing solutions. So trust me with your requirements, and I will propose solutions that fit your needs while having the greater goal of Symfonium in mind.
You can use the discussion part of the forum to discuss between users, but no support or feature request related topic will be answered by the staff.
Common issues
- License issues: Troubleshoot license and purchase issues
- Playback stops: Playback stops randomly / Thumbnails (Images) are disappearing
