Symfonium for Android TV (Experimental Build)
As part of the ongoing efforts to improve Symfonium and explore new platforms, I’m sharing an experimental build of Symfonium for Android TV. Please note that these builds are not yet optimized for TV, but they are provided here for convenience for those who want to try it out.
The application is now officially available on Play Store.
Important Notes
  • The interface and navigation are not fully adapted for Android TV.
  • This is an experimental build, and some features may not work correctly with a D-Pad or remote.
  • Please share feedback about anything that does not work properly with the D-Pad so I can work on improving these in future releases.
Known Issues
  • This build is not optimized for remote or D-Pad navigation yet.
  • Some UI elements may not display correctly or be fully accessible.
Your Feedback Matters!
Please report any issues you encounter, especially if something doesn’t work well with the D-Pad. Your input will help make Symfonium better for Android TV in the future.
Feel free to reply to this thread with your feedback or suggestions.
Thank you for your support and patience as I work on bringing Symfonium to more platforms!
Hi,
I installed this APK on my TV today. The only issue I have is that the “Cursor” gets stuck on the volume slider as soon as I try to change the volume, when using the remote. There is apparently no way to go from there other than to force close the app. Everything else seems to work just fine.
It’s great that you try to bring this awesome App to Android TV as well, expanding your user base.
Kind regards
Chris
Can you make a video so I can see exactly how to repro ?
Thanks for the quick response, I’ll do that, might take some time though, cause I suffer from a tremor :blush:
Sorry for the shaky vids, hope they are still somewhat useful…
Another Idea that came to my mind was to go for a numeric volume indicator instead of a slider…
What are these icons called so I can put them up top or something?
The is the exp android TV build with large tablet mode. Is this the view that is recommended for TV?
Thanks :folded_hands:
There’s currently no style pre built for TV. But Large tablet is probably not a good one.
You can configure everything in now playing landscape with preview. This is the bottom bar.
Will see to have a simple working style as a starter.
What theme are you using and any other tweaks can you recommend for TV navigation? I can’t find one that allows me to use my remote to get to the previous or next track buttons.
Hey, you are really on to something special here. I’m a bit of an audiophile and have a lot of 5.1 & Atmos mixes I like to play in the home theater. Gapless playback of Dolby stuff is almost impossible unless using a single file and cue sheet. That is until now! Symfonium is the the only app I have found that can use my remote library and get gapless playback of Dolby Atmos and eac3 encoded content on my Nvidia Shield. It may work on other Andriod TV devices but have not tried any others. I really hope you bring a full tv version to market. The tech you are using to pass the bitstream is flawless. I think Nvidia still needs to work on better decoders as I do get micro stutters after a really long listening session and it seems only a restart of the device fixes it. That’s not Synfoniums problem because Kodi suffers the same. Kodi will also play gapless but i find it clunky and my remote music server is Jellyfin because Plex will downmix anything that doesn’t have video. So, integrating a remote server with Kodi is not fun. Even with passthrough, Plex found a way to only serve stereo streams. I know the 5.1 music market is kinda niche but we are here and usually have money for anything that makes music go boom. Keep up the good work and make sure people know Symfonium can play gapless Dolby Atmos albums. Iwould have already posted something on Reddit but the TV control has a lot of work needed, as you know. Thanks!
Really excited for this, there isn’t a fantastic jellyfin android TV app for music right now imo.
I’d eventually love a UPnP feature, like kodi has, where it hosts it’s own upnp server that you can cast to from the symfonium phone app. This is the best way I’ve found to get gapless playback with casting, since casting straight to my nvidia shield doesn’t have gapless playback.
Hi there,
since I have issues getting the volume bar going on my TV, I’ve disabled IT and use the remote of the receiver for this. Still looks amazing with the new Interface in version 12.1..
Could you share your theme? Looks great!
I’d love to share it but I’m unable to save it due to the crappy file management of my TV, sorry😔
Could you share a little on what you did? I’m still losing focus when I try to move focus over to the Next, Play, Previous, Artist buttons on the display with the remote.
At first you you need to disable all the buttons you don’t need and set the alignment for the rest of them. This is all done in the menu for the landcape mode.
I use the Bluetooth Mouse App for changing some settings, as they are hard to reach with the remote.
Hope this helps a bit…
As for the color and shading settings, just fiddle around with them and see what looks best on your tv
Hi there, I finally figured out how to export the Themen on my TV
