"Sort by" for playlists in Android Auto should match settings in the App
AA sorts alphabetically which makes difficult to easily find Playlists. Especially if you have a large number of playlists.
A workaround will be to automatically carry over the current setting from the app to AA.
Makes it easier to find playlists while driving. It mimics the app setting.
Flexibility
Can we have this for all other lists in AA as well (e.g. artists)? :wink:
Already told you no due to the mandatory letter split :wink:
Huh? You said “open a feature request”
:person_shrugging:
You are confusing me with someone else
I’m answering to Splinter…
Ahh, my bad. I need my coffee
