Light and Dark custom themes based on Ethan Schoonover’s Solarized colors.
You can either use the “Solarized” file to be able to automatically switch between dark and light mode using Android system settings. Or use the “Solarized (dark)” and "Solarized (light) files to be able to manually chose the mode to be used.
Note: You can only install one custom theme at a time, so keep all the files on your device to be able to switch between them by using “Install custom Theme”.
I could not test all the color values, though. For instance, I did not find secondary, tertiary and error colors anywhere in the app, so no guarantee they harmonize well
Only the colours on the sources drawer could be optimised - not sure if that can be changed separately, but the “card” background is neither visible for active nor inactive sources:
@splinter Thanks a lot, a missed that probably because I only had the Local provider configured. I did add a Kodi source now and fixed the colors. But for me the colors for “online Kodi” and “offline Kodi” are always the same.
I updated the Theme in the first post and added Source filter examples.
How can I set a source as “inactive” like FluffyPie in your screenshot?
