Single track won't loop after 2nd time
When I switch the looping type from others to loop single track, Symfonium will only repeat once.
i.e., it plays the song twice but not the third time.
After playing the song for 2nd time, the seek bar shows an incorrect end time (see screenshot).
If I press the play button in this situation (extended player not showing the song’s end time), it won’t play the song.
Upload description: single_loop
  1. Switch to loop single track
  2. Play the song twice
  3. Won’t play the third time
Any provider
Thanks, will be fixed in next release. Probably broken since quite some time I guess repeat 1 is not that much used :slight_smile:
Just had the same problem - I hope it is fixed. This is one of my favourite ways to consume music, and I just bought the app. Please fix asap, as I’d hate to have to find another app now…
It happened to me JUST today. So, it isn’t ‘fixed’.
What do you need from me to help?
To wait until the version with the fix has passed through beta phase (unless you are part of the beta tester program, which does not seem to be the case) and reached the general public.
