Shuffle mode Chromecast
When I want to play music from my SD card via Chromecast in shuffle mode, there are large pauses between two songs.
If only there was message everywhere and a template that explains how to open issues …
Be sure to read the following link for how to gather logs.
Any issue without the logs can be automatically closed without any further notice.
Add as much details as possible, including reproduction steps.
Hi have the same problem while casting to nest home with telephone screen locked…
See https://dontkillmyapp.com/ to remove Android optimisations that slow down the app when screen is off.
To workaround a little you can disable the transcoding engine the settings.
