Posted as a follow-up to this discussion
If there are too many “Main navigation entries” enabled and the Settings button is included, users may become unable to access the Settings menu.
This specifically affects only the “Bottom floating toolbar” style (and all of its variants).
The “Bottom docked toolbar” style is affected to a lesser degree. The icons scale down enough to be invisible, but the user can still blindly click the button.
All
- Enable a large number of “Main navigation entries”
- Arrange these entries such that Settings is at/near the last position
- Set Navigation style to any type of Floating toolbar
If testing the Portrait styles, I advise you to leave Landscape set to “Bottom tabs” so that Settings can be still be accessed by rotating the device. Or vice versa.
The exact number of entries to be “too many” will vary based on screen size.
Screenshot for “Bottom docked toolbar (15 icons)” shows that icons are invisible, but Settings was still accessible by tapping the correct spot.
For “FAB” styles, if Settings is in the last position, it remains accessible. (The floating button is still visible.) Other positions may still run into this issue.
Celorien_HiddenSettings
