Notes:
Debug
Debug mode
Enable Symfonium powerful logging system to help support diagnose your issues and fix them. See How to gather logs and open an issue
This mode can generate very large logs and slow down the application a little to write them. Please only enable it when you have issues.
Share logs with support
Securely upload the current log file to support. You need to contact support after since the files are not manually checked and automatically deleted after a couple of days.
If you cancel the operation you can use the Manage Symfonium generated files to send the proper one.
List and manage all the files that Symfonium can generate, like backups, logs and ANR reports.
You can easily delete them or save/export them.
Don’t kill my app
Open https://dontkillmyapp.com/ to get some useful information about how to fix some devices bad behavior that can prevent Symfonium to properly work in the background.
Miscellaneaous
Settings PIN code
When set, a PIN code is required to access the settings, preventing unwanted modification by kids for example.
Cleanup
Clear image cache
Clear the image cache. Useful if you changed a lot of images on your server or switched to another server.
Clear media info cache
Symfonium store precise information about media during playback, pressing this clear the cache, can be useful if you updated a media but kept the same file name.
Clear playback cache
Press to clear the playback cache in case of corruption. (Should never be needed)
Cleanup internal states
In some very rare cases some internal state of the application can be invalid (App killed at the very bad moment). If asked by support pressing this should fix any wrong data state. (See https://dontkillmyapp.com/ to reduce the risk of app kills during syncs)
Support
Anonymous analytics
Enable fully anonymous analytics to a private Matomo instance. This is really useful for me to have some insight about the application usage and what should be prioritized as new features / improvements.
Anonymous crash reporting
Full anonymous crash reports. This is really useful for me to have some insight about the application crashes. But if you experience crashes it’s best to contact me with details as those crash report are most of the time not self sufficient.
Disable media session usage
Some very rare devices have a bug with Media Session handling and can use too much CPU. This is very very very rare and should only be enabled when asked by support.
Restore defaults
This button restores all settings on this page to their default values. You can also use the backup and restore function to switch between different configurations of the settings with ease. (Settings - Backup & restore)
