Separate export option from download to cache.
Imagine downloading some albuns, or even just some songs of an album.
Right now, this needs a four step process.
1- You select the media you want to download,
2- select cache/download offline,
3- then check export to the downloads folder
4- finally you hit “Export”.
This is painful, especially if you want to download your songs for offline access by every other app on your phone.
Way simpler workflow for downloading songs.
This feature is related:
