Selecting a track can cause the incorrect metadata
Sometimes selecting a track from an album will randomly load the track, but with the metadata of the first track on the album. The track time will not be displayed either. Offline syncing will start from the beginning of the album as well, instead of from the selected track
Seemingly random, but logs have been sent.
Upload description: sentinian
Open an album
Play any track after track 1
It will randomly load the data of track 1
I will need a lot more details than this, the logs cover a full day, so if you do not tell me at least the times things happens I can’t do anything.
In the logs sent, it happened during playback of the track “n95” the app loaded the metadata for “untied in grief” both of the album “mr morale and the big steppers”
Unfortunately its annoying to recreate since its seems to be completely random, hence the extended logs until I got the issue itself.
This is probably a variation of the other reports.
Please test back with next beta when it’s out and report with new logs if it still happens.
With the first beta of the new version, I’m getting an issue where it plays the last track of an album after selecting a different one from the album tracklist view.
Tolriq do you need dubug mode on when it happens? It seems quite hard to predict.
Open your own issue and yes I’ll need logs.
Hello, I am having similar issues, I intend to write my own report with logs.
but I wanted to ask, how is it possible to join the beta? Whenever I view the app on the Google Playstore, it says the beta is full.
Best regards.
Beta program is managed by Google, I think there is not much that can be done except wait.
