Repeat mode works only once
Hello, I’d like to explain my problem with the repeat mode, which I use to repeat the music once with the number one key. The music repeats well, but then stops, although it seems to me that when you activate the repeat mode, it should repeat the music in a loop.
I attach a video if you need it
Upload description: not understand
Step
1 launch music via album with a single track
2 activate loop mode wait for music to end or set version to end
3 music will restart as it should
4 wait or force music to arrive at last second
5 find that the music stops looping and restarts at the same time by pressing previous or next music.
AFAIK this has been fixed in the latest beta version of the app. You can join the beta program from playstore or wait until the update is out of beta.
Hello thank you for the information the problem is that the play store indicates that the beta program is complete and that I can not join.
For information i am french maybe a limitation in french location ?
Sincerely
The number of allowed beta users is determined by Google, and lately it is full most of the time. You will have to wait for the general release of the next version, which is not too far away I guess.
Hello
Ah ok I see and I guess who has no other way to get access to apk or whatever.
Because it’s still a function that’s used quite a bit, if not a basic function.
I’ll wait and see. Do you have any idea when it’ll be released?
There are never any dates set or promises made, but as you might have seen releases come quite often.
And there it is… Version 11.3.0 released
Hello thanks for information
but play store don’t proposed update …
Cordialy
Hi, it will take sometime to reflect on the playstore depending on the review process by google. It should be available within 24-48 hours, may take longer in rare cases.
Hey there, the update is available on playstore FYI.
Hello
How are you to day ?
I’m tested New version
The répétition mode is work for me
The problème resolved for me
Cordialy
