Recently Added representing Recently Modified in LMS
LMS 3.63 introduced the ability to use ENCODINGTIME as the driver for Recently Added, which is great for me as my file modification dates are meaningless at this point. This works well in the LMS webui, but Symfonium’s Recently Added instead shows Recently Modified.
The sync is from a test instance with a handful of test “albums”.
The Recently Added list in LMS is: Album3, Album5, Album2, Album1, Album7, Album4, Album6
The Recently Modified list is: Album6, Album1, Album3, Album2, Album5, Album4, Album7
There is a similar post but it appears to be specific to Navidrome:
Upload description: simbun
Symfonium displays what LMS sends as created value.
@itm ?
I did mention it during testing. Does this mean anything to you?
For the subsonic part, it is supposed to use file_added
We were working on an issue though, so maybe his focus was elsewhere.
Ah, the “created” value, maybe it is still badly set on lms side, will check this
