trumee
February 11, 2023, 11:25am
1
Hello,
I have a Qudelix 5K dac connected via usb to the android phone. The source audio is 44.1Khz but Symfonium is playing at 96Khz (as seen in the Qudelix app). On the other hand USB Audio player pro does play at 44.1Khz.
How do i get Symfonium to play at the source frequency?
Here is a screenshot from Qudelix when using Symfonium which shows 96khz.
Tolriq
February 11, 2023, 11:42am
2
Be sure to read the following link for how to gather logs.
Symfonium have a powerful debug mode engine that can be enabled when requested by support.
It gathers the necessary data to be able to see what is happening and is required to be able to fix issues.
Note: Logs generation slows down the app a little and can take a lot of space, do not forget to disable debug mode when you have finished reproducing the issue.
To enable logs just go to Settings then Advanced and check the Debug mode option.
[image]
You can then reproduce the issue while the l…
Any issue without the logs can be automatically closed without any further notice.
trumee
February 11, 2023, 1:37pm
4
Please can you let me know the best settings to use with external USB DAC (and not limited by android limitations) ?
Tolriq
February 11, 2023, 2:10pm
5
id=null, mimeType=audio/flac, bitrate=1382400, channels=2, sample_rate=44100, supported=YES
downstreamFormat [eventTime=2.90, mediaPos=6.00, window=0, period=0, id=null, mimeType=audio/flac, bitrate=1382400, channels=2, sample_rate=44100]
Symfonium handle all it’s chain at 44Khz and have no control over what upscale if whatever that application shows is true.
This is not possible with Symfonium and most apps.
