Problem importing playlists from local device
As requested, opening a new ticket with logs.
Mostly the same issue as: Empty m3u8 playlists
** Note: See “Steps to reproduce” for additional steps I’ve taken prior to opening this ticket. **
I have a debloated Pixel 8 that is exceptionally fast and responsive with all my apps, including Poweramp Pro, GoneMAD Music Player, Musicolet, and USB Audio Player PRO with my current library.
I’ve been trying out Symfonium these last couple of days because in my opinion, except these issues I’ve been running into with playlists, it is an overall better app that all the alternatives.
Specifically to my usecase:
  • Pixel 8, always on latest build.
  • 12’500 .opus music files are accessed locally on device (and no other music source)
  • Symfonium > Manage media providers > Local device > Automatic playlist import > is checked.
  • Auto sync is off because I only update my library once every six months, and want to set and forget.
  • Android Settings > Symfonium > App battery usage > Unrestricted
  • Proceded with cleared tag cache, forced stopped > clear cache > open app > sync
  • All the music gets added ridiculously quickly (4 minutes), which is insanely good.
  • Everything plays fine, which is awesome.
  • I’ve got 32 playlists, ranging from 400 to 9000 songs. Playlists get added slowly (takes around 15 hours), which really isn’t ideal but isn’t a dealbreaker for me, as it’s a compromise I’m ready to do for the ability to use Synfonium, and I can set it overnight.
With this context, here are the exact issues I run into (will copy paste some of what OP wrote because their description of the issues perfectly describes what I’ve encountered):
  • Each time the app syncs for new stuff, it tends to remove playlist contents. It still shows it contains files, but when I open the playlist it’s empty. It usually takes several hours (around 15 hours on my end) before the contents are back and usable.
  • During those 15 hours, when I click on a playlist, I also get one of those messages: “Nothing to display” or “Your data is being synced with your media provider”
  • As the playlists are getting synced (during the 15 hours process), sometimes they show 2x the amount of files in that playlists, and every entry is duplicated. I did not give much thought to that because I was considering that to be just a glimpse of what was happening under the hood, and in any case, once the sync was complete (fifteen hours later), that specific issue about the duplicated entry for every song was always gone.
  • Once synced successfully, there are always a couple duplicated playlists.
  • And when I delete one of those duplicate playlists, after half an hour or something, it removes the content of the remaining playlist.
  • After deleting a playlist that was duplicated, the remaining playlist runs fine for a while, but often, after a few hours, that playlist is deleted and nowhere to be found.
I initially thought it was a user problem, so I tried exporting playlists from MusicBee in .m3u, .m3u8, and .pla format, and that did not change the behavior at all.
I also tried without the automatic sync with the Synfonium > Playlists > Import > Local device, in both Offline first, and Read-only (in different runs), as well as through Files > Media providers > Local device > [playlists in question] > Import but all these different ways also resulted in the same results as described above.
For the sake of opening a new ticket, I made a backup of my settings, “clear tag cache” in app, then in android settings: force stop, cleared cache, cleared image cache, managed offline files (there was nothing to clear), and cleared the previous debug.log, then cleared storage, the uninstalled. Then went in Play Store and reinstalled with restoring my settings, immediately set background usage to “Unrestricted.”
The log I’ve uploaded is what resulted from it.
  • The music got added with no problem in a few minutes.
  • Around 5 hours after the beggining of the import/sync, all my 32 playlists showed up, but clicking on most of them displayed “Your data is being synced with your media provider. Please wait for the end of the process”
  • Around the 10 hour mark, there were only 26 playlist items (I have no idea why the remaining 6 are no longer displayed), and most of the playlists (including some that had visible content before) showed “Your data is being synced with your media provider. Please wait for the end of the process”.
  • Gave the app a chance and waited +24 hours in case that’s what the sync needed, and no change (most playlists still display the above message).
  • Submitted log.
love
Alright, I figured it out. I guess this can be set as “handled”, though I think it could happen often enough with different users to warrant a few feature implementations, and small notes in-app.
After a few days of trying more things, I think I’ve nailed the issue on Android shutting down apps background processes when the phone is locked (say after 30 seconds of inactivity) or shortly after, even when the app battery usage is set to Unrestricted, and both Battery Saver and the developer options to kill background processes are off.
I noticed that this was causing both Symfonium and Poweramp to have their respective library sync interrupted.
The work around I found was setting my Screen timeout to 30 minutes and periodically keeping the screen on by clicking on it once and a while until the sync is completed.
This solved 100% of issues I mentionned in this post; after the sync was successfully completed in a single chunk, all playlists were present, persistent, and even the 10’000+ songs playlists loaded within a second.
I’ve been using Symfonium for 12h since and I have yet to encounter any bug, so I’m considering it as solved as far as I’m concerned.
[As a reference, my sync took around an hour and a half to complete.]
That said, Poweramp handled that upstream Android issue more gracefully though (by always displaying the sync progress in a precise way as to let the user know how the sync is progressing and whether or not it stalled or crashed, and by resuming the sync gracefully without any error), in such a way that I never paid much attention to it, and didn’t cause further complications.
Here are the potential improvements I could see for Symfonium to avoid this issue being encountered by new users:
  • Displaying the progress in detail for playlist sync, with clear indications of if has stalled or crashed, rather than having “Syncing Playlists” being displayed for hours (and forever when the sync has crashed).
  • Under the hood improvements to the sync process to gracefully resume sync if interrupted.
  • Some way to prevent playlists from appearing and disappearing randomly after a crashed sync, or maybe displaying an overlay pop-up in the lines of “The sync has been interrupted. Playlists may be unstable. Recommended action: Sync library again and keep the device awake during the entire sync process.”
  • An in-app checkable option to keep the phone awake during sync.
  • Additional notes in the Sync menu mentionning that the phone must remain awake during sync, else it may cause some instabilities.
All this being said, now that I know how to avoid those issues, and that I had the opportunity to play more with this app, I am quite in awe with how you have taken “I will make a app to play songs” into an absolute masterpiece. And I’m not saying this lightly. You have literally solved every single compromise I’ve run into with every single other music app, and then took this one above and beyond what everyone else has been doing in a way that doesn’t even compare. To name just a few:
  • Your responsiveness as a dev is impeccable.
  • Your log uploading is a seamless experience.
  • Your forum is modern, easy to navigate, and intuitive.
  • The sheer amount of features you packed in is absolutely insane.
  • And more than just that, all of them work without hiccups.
Honestly, I don’t think I’ll ever be able to go back to another android music app.
This is the app I’ve been waiting for all this time.
Thank you.
Can a dev comment on this? It’s nice that it works but that doesn’t seem very convenient.
