Is there any chance that OneDrive will be added as a cloud music source? Thanks.
If they expose the data via SAF probably yes. If not way less chances.
OneDrive access please.
Been supporting and using Yatse for years. Your level of product customisation is incredible. Symfonium is of the same calibre. None of the other players that support cloud come close.
What is SAF? Can’t find the term on Google.
First result when searching on Google …
Maybe only if you search for Android terms regularly. In my case, all results on the first page revolve around this:
You are supposed to be far away ![]()
And yes of course when you search a 3 letter acronym you add some context as all those are used hundreds of times.
I see everything. And they even have Internet in farawayland.
