Worked as it should after a reboot, for about an hour.
I then had normal play with a BT speaker for about ten minutes.
Ten minutes or so, after that, then tried to resume play with a different BT devices, earbuds, and no sound.
If you watch the video I sent, it shows that there is no sound coming from the phone, after BT is disconnected . The Now playing screen shows the song should have audio output.
This is the first I’ve ever experienced this with the app.
How long can I run debug to catch whatever this may be?
Well, what I was trying to show in that video is that BT had already disconnected, and the media was playing, but no sound. The BT device was already disconnected.
What you saw was when I went to verify that BT was off, and then it paused, as it should.
I did try 4 different BT devices last night, switching between them, and of course, it ran flawlessly.
Could I run debug all the time, and then upload when it does fail, with just the time stamp?
Again, I’m not sure what has changed, as I have never had any playback issues.
As explained in the other issue, Symfonium does not control at all where the sound goes and what BT device get the sound.
The fact that BT device was disconnected but Symfonium had not paused, means that the OS did not send the information to Symfonium.
It only did it when you turned off BT confirming that for the OS the sound was still going out to BT and so was not noisy.
I sent you a video that you apparently didn’t even watch, as it showed the player chugging along with play progress with no output playing to the phone speaker. It was a totally muted. (That video has sound on)
Yes, when you disconnected Bluetooth it stopped. What you did t seem to see that was just to prove to you in the video that I was playing to the phone speaker with no sound.
I appreciate your efforts , and I think you have a great app, and even if you didn’t do anything, I’m happy it will start when it should and play to the output I choose now, without being muted
I did watch the video multiple times and it’s nowhere visible that you are playing not on BT and when you disconnect BT it stops as expected so that’s exactly what I explained.
Your voice on the video:
It’s playing there’s no sound, bluetooth off, it should be playing on speaker and it’s not. And at the moment you turn BT off the player is paused so obviously there’s no sound …
So everywhere you talk about beta 3, the video and your voice on the video says something different that what you try to imply now but somehow I do not understand the information that you give that is now the opposite of what you said and you provided …
So maybe the issue is that you just give the wrong information and also forced me again to request the logs and that as often I loose time? Or you are blatantly lying.
In all cases I’m quite pissed off actually either by the lies or the accusations in your last message.
