Would be cool to add your own fonts.
Especially Oswald or Roboto Condensed?
How though. Would you import the OTF / TTF files to symfonium?
If your device supports custom fonts then you could also just change the settings in symfornium to use your device font.
Also I have to warn you,
You ought to fully fill out the forum & not delete the whole thing or the dev may not even look at the request which would be sad because this one is interesting.
This is a duplicate of Custom (external) typeface - and back then it seemed not be technically possible.
Oswald is from Google.
Tolriq had said only fonts from Google could work.
I only meant the “add your own” part. He can bake any font into the app he wants (and has the license for - which is why Google fonts are easy).
@Tolriq hope you can add Oswald!
