Navidrome transcodes not correctly writing
Hello. My issue is, I think, very similar to issue 5178: Navidrome transcoding playback error?
I’ve recently moved to Navidrome and my FLACs are now only transcoding approx. 200B of data (from looking at the transcode queue.) This means that I cannot play them offline as intended. This function previously functioned well on Jellyfin (but no longer met my needs.)
I get the same error as the other error: “Error playing media, ensure that your player supports it.” and “Too many errors, stopping playback”. These files play fine on WiFi as streamed FLACs.
I’ve checked my Navidrome ffmpeg setup, and don’t see anything wrong, but I am quite new to this. Any assistance would be super helpful. Thanks!
Upload description: fromcassettes
If it returns 200 bytes then it does not work, check Navidrome logs it will probably explains why
After several attempts, managed to reinstall ffmpeg and get this working - thanks for suggesting!
