Multiple selection mode (no drag and drop)
Multiple selection mode (no drag and drop), simply select albums or songs and as long as the add, etc buttons appear without them disappearing, like bubbleupnp. It is desirable that the user in configuration selects the mode (drag and drop or classic).
For me the drag and drop mode is uncomfortable.
You know what’s a lot more uncomfortable?
You ignoring again the template, you not bothering to follow up app in the notification area permanently.
I’m sorry, it’s not that I ignore the template, it’s just that I haven’t seen how to use it.
There’s a bunch of text when you create post. You just have to read instead of delete.
