I love this freaking app. It is everything that I’ve always wanted in a local music app. One little thing if possible. Is there any way to NOT combine two different media providers? I use Emby at home and I use Local Device with an external hard drive in the car. The only way I know to do it is to delete one of the media providers. Is there a way to select one or the other without having to delete one? Thank you!
BRAVO! This app has everything. I knew it was there somewhere. Thank you so much!
Lurking around the Symfonium help pages about using LMS with Symfonium and I can not get it straight. I understand that under ‘Add Media Provider’ I am supposed to use (Open) Subsonic. I have my server URL from LMS. I have entered my login and password with no luck. I was going to use an API key, but that is where I have met a dead end. Where do I go to generate it? How do I generate it? Can I just use my LMS login and password? What is the easiest way? Thank you in advance. I love Symfonium and have been using it with Emby successfully..
With LMS it’s always API key either as API key or using the apikey as password.
See LMS docs. Ping @itm for a recurring point.
Ha! I thought LMS was Lyrion Music Server which is the new name for the old Squeezebox. I see now that it is Lightweight Media Server. Geez..
I looked for this setting for like an hour and was just about to submit a post about this but figured I’d give it one last look. Thanks!
