Manual album playlist
Although this topic has been discussed previously, I would like to know if there are plans to create album lists similar to “smart album playlist” but that we can add manually.
Thank you
Being able to manage album playlists
Another way to classify albums. I use favorites but I would like to have more than one list.
If you want to have an album view on playlists you can already
  • Make a normal playlist and add the albums you want (one track per album is enough)
  • Create a smart album playlist and use “in playlist” as filter, refering to the first playlist.
Management goes through the first playlist.
Duplicate Playlists - View By Albums
Thank you, I will do so.
