M3u playlist in SAF mode relative path
Just a general question. Doesn’t fit the template.
“…only relative paths are supported for now”. Relative to what? Relative to where the m3u file is stored or the selected media provider folder?
The former, otherwise the playlist would only be usable for Symfonium and nothing else.
Yes as he said :stuck_out_tongue: and how m3u works.
It’s just that non relative full path don’t work thanks to all the Google limitations on direct file access now.
