I can’t seem to find the JSON for the default, red Symfonium theme – is it available somewhere I’m not looking?
I want to use it as a starting point for a custom theme, making just a few changes.
You can just save it under a different name and then edit it.
How? Every time I click on 'Create" in ‘Theme, Font, and Colors’, it reverts to some other pastel color scheme
You are right, I thought of application styles.
@Tolriq, can the Symfonium theme be added here as an example theme file?
I don’t have it in JSON format and IIRC Splinter you did that theme so maybe you still have it somwhere ?
Here’s the colors you can copy paste them.
light = MaterialScheme(
primary = "#FFE22628",
surfaceTint = "#C00014",
onPrimary = "#FFFFFF",
primaryContainer = "#D61C21",
onPrimaryContainer = "#FFFFFF",
secondary = "#151212",
onSecondary = "#FFFFFF",
secondaryContainer = "#FFB8191A",
onSecondaryContainer = "#FFFFFFFF",
tertiary = "#754600",
onTertiary = "#FFFFFF",
tertiaryContainer = "#7C1516",
onTertiaryContainer = "#FFFFFF",
error = "#BA1A1A",
onError = "#FFFFFF",
errorContainer = "#FFDAD6",
onErrorContainer = "#410002",
background = "#FFF8F7",
onBackground = "#281715",
surface = "#FFFFF6F0",
onSurface = "#000000",
surfaceVariant = "#FFDAD6",
onSurfaceVariant = "#595959",
outline = "#FFC51B1D",
outlineVariant = "#FFBEA18E",
shadow = "#000000",
scrim = "#000000",
inverseSurface = "#3F2B29",
inverseOnSurface = "#FFEDEA",
inversePrimary = "#FFB4AB",
primaryFixed = "#FFDAD6",
onPrimaryFixed = "#410002",
primaryFixedDim = "#FFB4AB",
onPrimaryFixedVariant = "#93000C",
secondaryFixed = "#FFDAD6",
onSecondaryFixed = "#410002",
secondaryFixedDim = "#FFB4AB",
onSecondaryFixedVariant = "#871F1B",
tertiaryFixed = "#FFDCBB",
onTertiaryFixed = "#2C1700",
tertiaryFixedDim = "#FFB869",
onTertiaryFixedVariant = "#673D00",
surfaceDim = "#F3D3CF",
surfaceBright = "#FFF8F7",
surfaceContainerLowest = "#FFFCF0E8",
surfaceContainerLow = "#FFFAE4D6",
surfaceContainer = "#FFF9DECD",
surfaceContainerHigh = "#FFF8D9C4",
surfaceContainerHighest = "#FFF6D0B6",
dark = MaterialScheme(
primary = "#E22728",
surfaceTint = "#FFB4AB",
secondary = "#FFFFFF",
onSecondary = "#670408",
secondaryContainer = "#A51C1E",
onSecondaryContainer = "#FFFFFF",
tertiary = "#FFB869",
onTertiary = "#482900",
error = "#FFB4AB",
onError = "#690005",
errorContainer = "#93000A",
onErrorContainer = "#FFDAD6",
background = "#1F0F0D",
onBackground = "#FCDBD7",
surface = "#151212",
onSurface = "#FFFFFF",
surfaceVariant = "#5D3F3C",
onSurfaceVariant = "#A6A6A6",
outline = "#A51C1E",
outlineVariant = "#605555",
shadow = "#000000",
scrim = "#000000",
inverseSurface = "#FCDBD7",
inverseOnSurface = "#3F2B29",
inversePrimary = "#C00014",
surfaceDim = "#1F0F0D",
surfaceBright = "#493432",
surfaceContainerLowest = "#201616",
surfaceContainerLow = "#252020",
surfaceContainer = "#272323",
surfaceContainerHigh = "#302626",
surfaceContainerHighest = "#353030",
Ok, great – I copy/pasted the color data you provided – here it is in JSON format, in case anyone else needs it. Thanks!
default_symfonium_red_theme.json (2.7 KB)
Says invalid theme detected
Thanks a lot…worked like a charm
