Hey
I’ve been using Plexamp for years, but I dislike the player because it’s too bloated and the “front page” when opening the app is “recently played, recently added, rediscover” and so on.
I just want an option for each library in Plex. I dont care about seeing recently added or most played.
So, I heard about Symfonium and saw the developer said it was very customizable. But! After installing, I’m met with the same bloat. I spend 15 minutes trying to tweak and change, but it keeps being bloat.
Under “source filter” I see my Plex server and I see 10 folders, each representing soundfiles for different occasions. Can I just have a very simple and plain layout with nothing but these folders? Is there already such a style?
Thanks in advance
EDIT1:
Okay I found this, and disabled everything. It’s a start!!
EDIT2:
I would love something like this, but instead of recently played, it just shows the “source list” from Plex. Then once you click a folder, you can shuffle from all files in said folder.
Maybe an option to toggle the folder on / off in “home page” settings could be added? I would definitely pay for that….
