The application would support jukebox mode of the subsonic API
Right now, the application does not support this mode
Symfonium is the best subsonic client in my mind on android, it would be awesome, if I could replace volumio with navidrome + symfonium setup
Tolriq
2
Duplicate Jukebox mode support , this is a stupid limit API, just install An UPnP Audio Media Renderer based on MPD and cast it will work a lot better.
This is an API, which works well. Unlike upnp, my music will not get resampled, it gets played directly.
Tolriq
4
No it’s ultra limited in the case of Symfonium features.
And no UPnP does not resample of there’s no need to. No idea where you get that false idea from.
Unpnpmpdcli will give you the exact same sound quality as the same exact original file will be played …
