Invisible musics after sync
Hello everyone, I’m French, so I apologize for my poor English.
I’m a beginner in this field, so I’m probably doing something wrong.
On the app, when I sync my music, it doesn’t appear (on the “tracks”, “artists” screen, etc.). However, it does show the number of tracks, albums, and artists. Furthermore, when I go to “folders,” I can find my music.
I don’t understand what the problem is.
Thank you in advance for your answers and wish you a pleasant day.
Nicolas.
Upload description: Nicolas
Téléphone : Samsung galaxy S22
Serveur : Airsonic, installé sur docker, sur un NAS Synology DS923+
Airsonic en HTTPS, en passant par un reverse proxy
Do you maybe have a filter active? Check the filter icon in the top icon bar.
Go to advanced settings then cleanup internal states.
Else uninstall then install again and be sure to enable compatibility mode on the provider.
I don’t see other filter.
Thanks for your response.
Great, it worked!
I deleted all the data, removed the server, and reinstalled the app.
I think the problem was caused by the fact that I was trying multiple times with my server, with multiple copies, versions with local IP addresses, HTTP, https… It was probably causing conflicts.
Thank you very much for your help and responsiveness.
Have a nice day.
