I can't seek songs when transcoding is enabled
I enabled transcoding for mobile data. It’s working, but I cannot seek songs. Probably related, because it started after changing the transcoding settings: when my phone loses connection for a brief moment, the songs start over from the beginning.
This issue does not happen with the web player and another mobile player that I tried when transcoding is enabled. I see “seeking disabled” in the Symfonium logs. However, I don’t know where and how I can enable it.
My server is Navidrome on Windows.
This is more or less normal, Subsonic transcoding does not support seeking so require restart at position.
Many servers do not properly support that so it’s disabled to reduce support and issues.
You can enable the option Playback cache in the settings to avoid issues with network instability.
But why not let the user seek in a song once a track has finished transcoding?
Server-side transcoding is done on the fly, there is no notion of “finished”.
