How can I sort by rating?
I’m missing being able to sort by rating. I’m surprised it’s not in the ‘sort by’ menu. Hoping it’s buried on some setting screen I haven’t been able to find to be able to add it.
Upload description: not applicable
Go to album screen
Hit the ‘sort by’ area on the top left of the track list
Look for ‘rating’
Fun fact logs are always mandatory…
This is the a actual album sort menu. So you are probably using a quite old version.
Is it old? I have version 12.0 with the Now Playing screen customization previews and stuff, I just checked. And the store (Aurora) doesn’t show me that I need to update.
Re: the logs being mandatory.. Didn’t know. However, last time I checked the logs, they had more identifiable information that I was comfortable with uploading as is.. so I had to scrub it manually.
Really? The support form you filled out literally says:
The logs are mandatory for each and every support request
and you had to check a box to confirm that you uploaded the logs.
So you do not trust the developer of this app seeing that information, but you are running his code on your phone which easily could collect and upload the same information without you knowing it. Just saying…
If you want to get support, you will need to provide the basics, and as stated numerous times in the forums, the logs are the minimum basics.
It’s not the developer I don’t trust, but where is it stored, etc. I mean, it’s not exactly Linux isos that we’re playing with this app. When I get some time I’ll upload the logs. Will try just clearing the cache and see if that fixes it. I did see that the star rating disappeared from now playing after the upgrade and I had to enable it again.. something probably went a little bit off with the update on my end.
The Now Playing screen layout was reset with the update because of the massive changes, so that is normal.
Btw. @Tolriq, it seems he is trying to sort the tracks on an album page, and if I see it correctly you cannot sort by rating there.
Yeah I’ve seen after, unfortunately people think rules are for the others so it’s better to make people lose time than follow them :wink: Logs, not for me, screenshot let’s remove half of it to not show where it’s from.
And the logs are directly stored on the CIA servers don’t worry, Trump is licensing all of them, no one is left to read them. And as he said I could already be sending everything to any server you’d probably never know …
As the upload dialog says, the logs are automatically deleted after some times and securely stored, the CIA is really good at security.
I did put it in the reproduction steps “go to albums screen”.
HILARIOUS.
