There are no more tabs or shortcuts on the homepage on Android auto
Navidrome
From the now playing page click the back button.
there is a landing page with recent albums played
mcalpine.andrew
Tolriq
2
What version of Android Auto they send wrong data.
Tolriq
5
Is it -release ? Or are you in the beta or soemthing ? Try to force stop it clear it’s data ?
I’m experiencing the same issue.
Android Auto 17.8.663814 release
If it helps, jellyfin app is also showing a similar issue on my android auto.
Tolriq
7
Duplicate read above
That’s an Android Auto bug, clear it’s data / cache force stop and reboot the phone.
