It was similar to this issue. Filter input field in playlist doesn't work well with IME
In the filter input, if the filtered results are less than a certain threshold (some number between 37 & 61), it will break the Gboard Japanese input.
I recently switched from SwiftKey to Gboard, and this bug only happens with the combination of Gboard & filter input. Gboard has no problems with my other apps & Search tab input in Symfonium.
Expected behavior using SwiftKey:
“かけ” is underlined, indicating it is pending, not the final input. I can add “゛” to “け” to type “かげ” or choose a candidate like “掛け”, or continue typing.
Bugged with Gboard:
“かけ” is confirmed before I can do anything. I can not type “かげ” nor choose “掛け”. This causes trouble typing tons of Japanese words.
Upload description: jp_sw_gb
- Use Gboard Japanese as input
- In filter input, type a word that matched less than 37 results (threshold may be larger than 37 but no larger than 61).
Any provider
