I use my local network at home to listen to music, and use a VPN outside the house. So I have to add 2 addresses per instance. This isn’t much of an issue if I manage only one instance. However, Navidrome don’t allow multiple libraries like Jellyfin does, so if I want to separate the libraries I have to start multiple instances. So adding two addresses per instance would be very confusing. It would look a lot better if I could aggregate and display instances by the same ip.
Prevents too many servers to show up and hard to use when VPN and local ip are added.
Or it would be nice to be able to group when adding media providers.
I see similar feature already mentioned in this thread. However, I made a new thread because the functionality is a bit different from what I had in mind.
The problem is that the instances on the VPN and the local instances are displayed separately.
I think there are quite a few people using vpn to access from the outside. I think it will be easier for such people to see.
Symfonium displays Jellyfin’s multi-library in the same button
