Equalizer with greater precision
Equalizer with the same precision that AudioLab has.
Setting an automatic gain control (AGC). This feature is present in Stellio Music Player
Equalization is not very accurate. I need an equalizer as good as the one in AudioLab. I’ve tested more than 100 equalizers and I want your music player to be the best in the play store
Another important function: Automatic Gain Control (AGC); This is necessary since I have high-quality music with different volumes.
It makes the application more competitive, more complete and more accurate. I’ve tested more than 100 equalizers, and yours has the potential to be the best on the play store.
I hope you look kindly at my requests. Hugs!
 Screenshot 2
Could you elaborate on what you exactly mean with accuracy and precision regarding the EQ?
What I mean is that if I, for example, download a certain channel, I want that frequency to disappear. Most current equalizers just lower the frequencies, and in some cases attenuate the frequencies. I’d like an EQ that cancels out the desired frequencies.
OK, that is neither accuracy nor precision, but an additional requirement that not even professional hardware EQs intended for playback equalizing implement (because it makes no sense most of the time in the playback stage, it is a production stage requirement). :slight_smile:
I really like Audiolab’s equalizer. The problem is that it is an audio editor, not a music player.
I’ve downloaded several equalizers, both graphic and parametric and none beats AudioLab. I hope your app can. I’m confident.
And that’s the reason why it can do things like that, at playing stage this is not really possible due to how EQ works.
I’m sorry but this won’t be possible in Symfonium.
What a pity that this is not possible. :sob:
