Empty synced playlists
Hi Tolriq,
My entire library is synced from a kodi server and files are cached on an SD card of the phone.
Playlists import works but shows nothing (cf. screenshot.jpg) whatever the import mode.
I would point out that everything was working like a charm on my previous phone (one week ago) from which I restored the working configuration.
Thanks for you help.
Logs and Screenshots:
Playlist_issue.zip (90,2 Ko)
Seems the songs are not matched with internalDB. Will try to repro later.
I have the same issue, sent logs via email.
Ok so yes a fix for something else broke this for Kodi only.
Will be fixed in next release.
