Hello, when a smart playlist is currently open and set to a random sort, selecting a track from it will shuffle sort order, even if not navigating away from the playlist. This can be inconvenient if scrolling through and choosing what to play, even if a different random order is desired each time the playlist is opened.
When playing or queuing a song from the open playlist using the three dots menu or by holding it down, the playlist order remains constant. I believe this behaviour is preferable when tapping the song as well.
Perhaps a pull to refresh can be added to refresh the sort order, like the random tracks section on the homepage has.
Allows a different random order each time the playlist is opened, and then the user can browse through and tap songs to play without the playlist changing.
see above - I believe this is would also be the naturally intuitive expected behaviour.
