I had a number of failed downloads in the download queue. They failed because the Kodi library was not cleaned up properly and had entries whose files did not exist anymore (the downloads failed with a 404). I tried to remove the download entries in the list with the “delete all” button, but to no effect. Deleting every entry manually worked though. I logged both actions.
Btw, I have another similar issue: two tracks are stuck in the download queue for a couple of days now. Cannot be resumed or deleted. When I look at the tracks, they are also shown as not in the cache (the rest of the album is). The problem probably occured due to lost wifi connection, but could not be resolved since. I did not try to add the tracks manually to the DL cache yet. Any cleanup should long be finished, and I had other tracks cached in the meantime.
@Tolriq, This might have slipped through during the summer holidays, but the issue mentioned in the last post still exists and was carried through several version upgrades. There are two entries in my download queue which never go away. I even removed and added the tracks to the cache manually in the meantime. Do you need any updated logs (doing what?)?
