If I try to cast a FLAC 16bit file to a GoogleTV box (with Android 11) never works. With MP3 it’s fine.
This happens with tracks on my smartphone and on Jellyfin.
If i uninstall the Chromecast updates from the Mi Box S 2nd gen, it works but with the latest update (version 3.72.425634 from 19th July 2024) it always crashes if I try to play (only) FLAC files.
I also tried with the apps from Plex, Plexamp, Jellyfin, Emby, Synology DS Audio, and PowerAmp (local); always the exact same file/song to see if it was an issue with Chromecast built-in but all worked perfectly fine.
Thanks
Upload description: • Kurt
Press the Cast option and then start playing an MP3 file. All good. Then, I change to the next track, which is a FLAC file, the Cast crashes.
It happens also if I start with a FLAC file.
Provide logcat from that device to see if it’s the same crash (It will be).
This is something that needs to be reported to Google so they fix, I’m using their most recent code on both sides, and without a broken device to reproduce to eventually try to workaround this Google bug (Yes I know OMG the others don’t crash so it’s Symfonium).
I gave the “example” of the other apps not to point the finger at you and your app but because I thought it was important to try out other apps and to let you know.
But yes, if all the others 6 apps don’t have any issue casting FLAC files, it seems that is something with your app. Which is not a criticising because sh*t can happens with any app!
And I know it’s hard to understand but in this case this is not the app, The Chromecast crash.
Chromecast expose an API, Symfonium calls the API, Chromecast crash. An non broken Chromecast would return an error if there was a wrong API call not crash.
And since those API calls works fine on nearly all devices for all the other users tends to show that the API calls are correct.
The fact that other apps probably use deprecates Google code that maybe avoid the issue does not change how things works.
And you actually have a workaround with the older Chromecast version. Since with works better use it ?
Don’t know if it’s bad form to necro a year old thread, but I ran into this issue too while playing certain FLAC files (other FLACs were working fine), and I can provide the section of the logcat when I noticed the crash. Notably there is an error about the sampling rate (384 KHz) coming from the AudioTrack class.
Logcat
2025-10-25 22:19:40.316 23794-23794 MediaControlChannel app.symfonik.music.player W received unexpected error: Invalid Request.
2025-10-25 22:19:47.606 23794-23794 SessionManagerImpl app.symfonik.music.player I Select default route from route with the selected route ID: 5527067c-bc3e-4493-a031-885a3ca5a60a-groupRoute
2025-10-25 22:19:47.607 23794-23794 AxMediaRouter app.symfonik.music.player W Changing selection(Living Room TV Box(BT=false, syncMediaRoute1Provider=true)) to default while BT is available: pkgName=app.symfonik.music.player- Stacktrace: [o7.e.k:223, o7.f0.h:9, com.google.android.gms.internal.cast.v.a:258, bv.i.onTransact:104, android.os.Binder.transact:1293, m4.rg.c:8, m4.uf.l:6, m4.tw.s:77, m4.tt.i:377, m4.te.A:81, m4.rh.onTransact:21, android.os.Binder.transact:1293, bv.a.J:41, fu.v.T:10, fu.f.b:8, bi.u.c:37, eu.y.run:92, android.os.Handler.handleCallback:1041, android.os.Handler.dispatchMessage:103, android.os.Looper.dispatchMessage:315, android.os.Looper.loopOnce:251, android.os.Looper.loop:349, android.app.ActivityThread.main:9041, java.lang.reflect.Method.invoke:-2, com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run:593, com.android.internal.os.ZygoteInit.main:929]
2025-10-25 22:19:47.609 23794-23794 MediaRouterCallback app.symfonik.music.player I onRouteUnselected with reason = 3, routeId = 5527067c-bc3e-4493-a031-885a3ca5a60a-groupRoute
2025-10-25 22:19:47.609 23794-23794 MRCallbackImpl app.symfonik.music.player I the route (5527067c-bc3e-4493-a031-885a3ca5a60a-groupRoute) is unselected with the reason: 3
2025-10-25 22:19:47.609 23794-23794 MediaRouter app.symfonik.music.player V Selecting route: RouteInfo{ name=Phone, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
2025-10-25 22:19:47.610 23794-23794 MediaRouter app.symfonik.music.player I Skip setBluetoothA2dpOn(): types=8388611, isPlaybackActive()=false, BT route=RouteInfo{ name=Chevrolet MyLink, description=Bluetooth audio, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO , presentationDisplay=null }
2025-10-25 22:19:47.611 23794-23794 AxMediaRouter app.symfonik.music.player W Ignoring attempt to select selected route: MediaRouter.RouteInfo{ uniqueId=DEFAULT_ROUTE, name=Phone, description=null, iconUri=null, enabled=true, isSystemRoute=true, connectionState=0, canDisconnect=false, playbackType=0, playbackStream=3, deviceType=0, volumeHandling=1, volume=11, volumeMax=25, presentationDisplayId=-1, extras=null, settingsIntent=null, providerPackageName=android }
2025-10-25 22:19:47.611 23794-23794 MediaRouterCallback app.symfonik.music.player I ignore onRouteSelected for non-remote selected routeId: DEFAULT_ROUTE
2025-10-25 22:19:47.624 23794-23794 MR2 app.symfonik.music.player W releaseControllerOnHandler: Matching controller not found. uniqueSessionId=com.google.android.gms/.cast.media.CastMediaRoute2ProviderService_Persistent:757c26b4-2b58-431a-a7b2-01106edf3a42
2025-10-25 22:19:47.644 23794-23819 android.me...AudioTrack app.symfonik.music.player E getMinBufferSize(): 384000 Hz is not a supported sample rate.
2025-10-25 22:19:47.644 23794-23819 android.me...AudioTrack app.symfonik.music.player E getMinBufferSize(): 352800 Hz is not a supported sample rate.
2025-10-25 22:19:47.794 23794-4115 VolumeShaper app.symfonik.music.player D setting id to 17
