Hi,
can you share a link to download beta versions?
cheers
mh
jaxz
December 6, 2022, 11:37pm
2
I just used Beta Maniac to get my way into the beta
Probably not the most ideal way, but hey, it worked haha
Tolriq
December 7, 2022, 6:36am
3
You join on Play Store there’s already threads about that.
Hi,
I looked there, but seems like you don’t accept new beta testers.
cheers
mh
Tolriq
December 7, 2022, 8:14am
5
According to Google there’s room there. I have no real control after that sorry.
Weird. For me it displays that, there are no slots for new betatesters.
Anyway - can you share an app on google drive or something similar?
Tolriq
December 7, 2022, 8:24am
7
No I do not publish APK because now the app is app bundle, beta build have expiration date and this triggers support for nothing.
Just wait for the release.
Ok, makes sense, thanks!
Do you know when the v3 can be expected?
Tolriq
December 7, 2022, 8:35am
9
When it’s ready ? I never give date since after that users are well users
playstore also shows as full for me to
“beta programme is full”
do you actually get any feedback through playstore for beta? as appears is no comments/feedback in the beta threads from users here (or is there also a separate beta forum?)
Version 3.0.0
Notes:
Symfonium is now Android 9+ due to abuse on the ratings about the equalizer not being present before and not enough ratings to counter that. Previous versions will still work fine on Android 5 to 8, but if you want a refund just contact me.
Please note that I’m not happy to have to do that, but it’s already hard enough to fight the “app should be free bad ratings”, Play Store is a jungle, your ratings have an impact.
Added:
New option: Hide favorite button from now …
Version 3.0.0
Notes:
Added:
Version 2.1.0
Notes:
Just a small reminder that Play Store ratings and comments are vital for apps, thanks for your help.
Added:
New option: Hide top filter button.
New option: Hide cast buttons.
Changed:
Prefer internal decoder option is now on by default as more broken devices than expected and users not reading changelogs. (But big thanks if you do)
Disabled advanced EQ on Android 9 OPPO devices as their implementation is broken.
Tweak add host wizard to better explain when the…
Version 2.1.0
Notes:
Added:
Changed:
Tolriq
December 7, 2022, 10:42am
11
Those threads are locked so it’s normal no one post there
The support happens here and many users do report things from the beta yes.
jaxz
December 7, 2022, 9:07pm
12
MIGHT I ADD AGAIN
ahem
If anyone wants to use the beta but Google is being dumb, I joined the beta through the Beta Maniac app, so I’d recommend downloading that, join the beta from Symfonium from there, and delete Beta Maniac or something.
