Hey, I’m noticing a lot of battery usage sometimes in Symfonium, but the Wiki/FAQ is lacking. What are some of the settings to tweak to lower battery usage?
Fill the template and provide logs and details …
Well or don’t ![]()
The Wiki is not lacking it present the only known case … So if you have an issue you need to provide the details for fixing … No magic in apps.
Appreciate it, but there aren’t any logs or details ![]()
The issue is with the FAQ. It doesn’t have any more information except a single example with Kodi.
The app works great, I’d just like to better understand the pieces of it that use a lot of battery, so I can limit it myself if I can live without the feature.
I guess my English is bad then …
I’ve just explained the situation there’s no known piece that should use lot of battery. So no the FAQ is not lacking …
And yes there’s logs and details you can provide to understand why on your device and your configuration and your usage it might use more battery than it should …
The template you deleted explained all that ![]()
