Artist Mix Builder
Would it be possible to implement a feature that will allow us to select 2 or more artists and start a mix of their music and music from other similar artists?
Not sure that it solves a specific problem but thought it would be another way to have a variation of music
Spontaneity
You can do the mix of two artists with a smart playlist, with parameters like “artist = X or artist = Y” and then random sort order.
The concept of “similar artists” is not stored in any tag/metadata, so that is probably beyond the scope of this app.
Otherwise you can use tags like “mood” (if oyur provider supports it) or even “genre” for “similar” music.
