After install, Error 404 trying to authenticate, how to progress
I am happy to have found this app which looks promising. However, after installing Symfonium, I clicked OneDrive as cloud provider, clicked sign in for Microsoft, authenticated the sign in request using authenticator, then i get
Error 404 when trying to authenticate to a cloud provider
I checked the app info for Symfonium and it shows
under set as default: Open supported links is enabled
under supported web addresses: the link is
callback.symfonium.app
under Settings, Apps, choose default apps, opening links,
open links in apps in enabled
Symfonium is shows “in this app” in the list of apps that can open links.
Also, in my Microsoft account, Symfonium is listed as having access to OneDrive.
My music is stored in one folder in my OneDrive. I am using Edge browser. What other settings can I check?
I have Samsung S22 with Android 16, UI 8
Upload description: oskoouser does not have app set up yet so cannot get to settings in the app. sorry, take your time.
click sign-in
at pick an account, click my account - there is only 1 and it says signed in under the name (the elipsis has options to sign out or sign out and forget)
microsoft offers me to get a code to sign in, using authenticator, i click get
i am shown a number which i can confirm by going to authenticator
i go to authenticator confirm the number and approve the access
i get the browser with error 404 etc.
One Drive
On Edge for Android, the toggle you’re looking for is here:
  1. Open Microsoft Edge
  2. Tap … (menu)Settings
  3. Go to Site settings
  4. Find Block opening external apps and make sure it’s OFF (so Edge is allowed to hand links off to Android apps).
I’m good. Had to clear cache also. Scanning files now. Thank you!!!
