I would like to suggest a feature of adding a small button (kinda) where we can scroll back to the current lyrics line if we scroll down !! This is for synced lyrics
Breaks the immersion flow while listening to music
Time consuming to manually scroll back
Quickly goes back to the lyrics line to match the song
Enchanced user experience
Tidal has the feature for now !! Would love to see in symfonium!! Thanks for considering.
By clicking that button we can come back to the lyrics line where we were listening !! Thanks
Firstly…love this song. I have the COLORS SHOW version (live)
This button already exists if im not mistaken. & it looks very similar to the icon you are pointing at here
In the full (standard) lyeics view this button lives in the bottom left corner & I believeit does what you are describing.
This will always keep the current lyric in view & this setting is also applied to the floating lyrics view
Firstly love that album a lot !! The artist is just too good !! Second of all sorry to ask a dumb question but where is that button located , like how to switch on explicit Tag ? i got to know about that button for the lyrics , so silly of me to !!
Thanks a lot man
For me if I long Press My album art on the Now Playing Screen it pulls up Lyrics.
So youll need to configure some way to enter the lyrics view from your now playing screen
The Now playing screen settings are under the interface section
I have a button in the “bottom” bar to toggle the cover & lyrics aka the floating lyrics. With this setup i can edit how my lyrics appear in the standard lyrics view & floating view.
Alll edits to the appearance of lyrics need to be made in standard view.
Explicit symbols can be toggled under media provider settings
Settings > manage media providers > 3 dots > edit >
Make sure “ignore explicit tags” is off
Note youll need to ensure your files have explicit tags in the metadata
You can use either tag
How to edit that meta data or like which app to use to do that ? I got no idea !!
, just the app name will be enough , rest i will handle on my own !!
Musicbrainz Picard , MP3Tag. Use a search engine, there are a few options.
I use MP3TAG on PC great tool when I get home I will send my configuration file to help streamline your explicit tags. I’ve created an action in MP3TAG that applies explicit tags.
It essentially. Reads the lyrics & figures out whether it is explicit or not “Damn” does not trigger explicit tag for me but almost all the other choice words I could think of do trigger the Explicit tag.
I think In my setup I have a couple extra tags that get populated when you run the action. You may want to scrap those but you can always add onto or edit my original action to get rid of any unwanted tags.
Edit:
MP3TAG Configuration File
https://drive.google.com/file/d/1shsoZh_9Qc-EEJ9wIJmaG7NJkQHyJgHJ/view?usp=drive_link
Hi, could you share your theme in json? The player looks amazing!
I’ve Shared it HERE with an explanation of what all you’re seeing. I’ve made some slight edits to it since then but check out the full walkthrough & let me know if you want / need my most updated version.
